Define Length as a Variable?
Posted Jan 16, 2011, 12:20 a.m. EST RF & Microwave Engineering, Geometry Version 4.1 13 Replies
Is there a way to define an object's length as a variable in COMSOL so when I change the value of the variable, the object automatically changes lengths?
I have noticed that making the length a "constant" does not work. When I change the value of the constant, the object does not automatically change lengths. (It is necessary to re-enter the constant in the objects' dimensions.)
It would be very helpful if I could define an object's dimensions using variables when I have many instances of the same object scattered throughout the design.
If it is relevant, I am using COMSOL 3.5a.
Thank you,
Kevin
Thank you,
Kevin
I don't think it is possible in Comsol 3.5a, but it is in Comsol 4. The workaround is to use matlab and comsol, and run all the code in matlab.
Comsol 4.1
Ubuntu 10.04.1
if you are talking about geometrial objects, you cannot give them a variable name in 3.5a, (in v4 yes).
But you can give them a constant name.
However, in contrary to 4.1, there is NO "big loop around the geometry" in 3.5a. The idea, I believe, was that one used matlab for that.
Just to clarify, are you saying that there is a way to define an object's position and dimensions in Matlab and then import them into COMSOL? Is that what you mean?
If so, would you be able to direct me to some documentation of how to do that?
Kevin
I understand you are in v3.5a, if so, you can have COMSOL to save a ".history" file (see the presferences), while programming the GUI, by studying this file and cross checking with the command.pdf you should be able to find out how the commands for geometrical components are set-up (I assume you need the Length in a geometrical object for your model).
Today you can define constants (parameters in v4) and use these in 3.5a for the definition of your geometrical shapes, but not variables.
The thing is that you need to loop around the geometry + mesh + physics to update a geometrical size dependent shape and the normal parametrical sweep is NOT looping arounf the geometry and remesh function
Thanks for your reply. I found the The command.pdf, and it is very helpful and detailed.
However what is a .history file, and how do I save a .history file? Is it a format when exporting a geometry object? I don't see a .history option when I go to File - Export - Geometry Objects to File.
Also is there a way to generate a ".m Matlab" file from a design in the GUI? It would be helpful to see an example ".m Matlab" file for my simple geometry. (I'm not certain if this is what you are talking about with the .history file or not.)
I very much appreciate your continued help with my attempt to learn different aspects of COMSOL.
Thanks again,
Kevin
However is there a way to specify the boundary conditions in MATLAB for these objects and then import the boundary conditions into COMSOL? My final design is going to have a ton of objects, so it would be nice if I didn't have to click on each line manually in COMSOL to set the boundary conditions.
Kevin
Me and some other users had the same problem in the past. It is possible to set and solve the complete model in Matlab, without seeing one pixel of the Comsol GUI. There are codes in this forum exists to find the right boundaries of your objects and apply boundary conditions to them. You can check "Numbering of the boundaries in *.m file"
/Onur
Thanks for your response. However, to be honest with you, I don't fully understand every aspect of COMSOL, so I would prefer to be able to just import the geometry objects (which I know how to do now) and the boundary conditions from MATLAB rather that specify and solve the entire model in MATLAB.
How to specify the entire model in MATLAB would be arduous and lengthy task to learn. Ideally after I import the geometry objects and boundary conditions from MATLAB, I would then solve the problem in the COMSOL GUI. (There is some surface and contour plots on the GUI I would like to look at for my design to.)
Do you know if it is possible to import the boundary conditions without worrying about specifying and solving the entire model in COMSOL?
Thank you,
Kevin
Kevin
I've got similar request to Kevin's.
I'm training myself to be professional user of COMSOL (4.1).
The thing I would like to do is to solve a problem (i.e. finding all mode profiles in an optical fibre), sweeping it against a geometrical parameter (i.e. the radius of the fibre's core).
I tried to experiment with defining parameters and variables and it didn't work. However, I'm sure there must be a way to go as it sounds so much like a standard problem.
I would be extremely grateful for any hints.
Kind Regards
Oleg
in v4 define a parameter as radius = 100[um] or whatever size, use the "radius" to define your circle radius
set up a parametric Sweep solver node, define parameter and gie it a range, then add an eigenfrequency scan (for yu mode analysis) set the required parametrs frequency ... And (normally) off you go that should be it.
You have a few examples of step index fibres in the library
I think I've succeeded for now. Thank you very much for help!
Kind Regards
Oleg
