Hello Jean-Michel  Poirier
                                Mar 16, 2011, 9:40 a.m. EDT
                                                    The best way is to plot the impedance of the piezo cube and check the resonances
User COMSOL
User COMSOL
                                Mar 27, 2012, 5:46 p.m. EDT
can you explain me how i can plot impedance?my project consist a zinc that some Al electrodes are on that,i apply 10v to one of electrodes and i want to get resonsnce frequency and admittance value(matrix) but i cant.
                                Aug 21, 2012, 5:26 a.m. EDT
                                                    Hi there,
I did a similar analysis using version 4.2a. Instead of applying an electrical potential, apply a terminal constraint of voltage type. Then after the frequecy domain analysis if you plot -- abs(1/imag(pzd.Y11)); you will get the required impedance trace. Looking at the impedance trace, you can find the resonance and anti-resonance frequencies of the model.
Hope it helps.
Anurag Dhutti
                            Hi there,
Hope it helps.
Anurag Dhutti
                                Sep 8, 2012, 10:02 a.m. EDT
                                                    Hello Anurag:
      I began to study comsol lately, could you tell me how to plot the connection of impedance and frequency. when I try your suggestion why the software tell me: failed to value the expresion imag(pzd.Y11)  and  abs(1/imag(pzd.Y11)). look forward to your reply.
thank you,
yang
                            Hello Anurag:
thank you,
yang
                                Sep 11, 2012, 5:42 a.m. EDT
                                                    Hi Yang,
The only reason I can think of is that you might have assigned an electrical constraint of 'Electric Potential' instead of 'Terminal'. Assign Terminal constraint type on the desired surface of your geometry and then in the properties window, you can choose the terminal to be a 'Voltage Type' of the desired voltage.
This worked for me so hope it does for you, but if it doesn't, I'll be happy to look at your model to get a better understanding of the problem.
Best Regards,
Anurag Dhutti
                            Hi Yang,
Best Regards,
Anurag Dhutti
                                Sep 11, 2012, 11:25 p.m. EDT
                                                    Hi Anurag,
Thanks for your reply. Yes you were right,  I use the wrong electrical constraint. Now I have done the impedance analysis. But I want to know that whether "abs(1/imag(pzd.Y11))" is the image part of the impedance?
If I want to konw the real part of impedance, am I right to use the function "abs(1/real(pzd.Y11))"? But in my model, the curve "abs(1/real(pzd.Y11)) vs frequency" is nothing. it is so strange, I don't know why, could you help me?
Besides, my model is a very simple one(just for try): a pzt film, one surface is ground, the other surface is terminal with voltage. frequency domain  150000:1000:750000.
Thanks for your time
Yang
                            Hi Anurag,
Yang
