Using 2 Models - duplicate variables?
I want to plot the difference in surface temperature between a model that experiences deformation and one that doesn't. By looking through the COMSOL forums, I found that I should be able to create 2 models, and solve for each in separate studies. Then I should be able to say plot(mod1.T-mod2.T) or something like that.
Anyways, when I go to solve I get the error message, 'duplicate variable names'. The variables listed in the error message seem to be global variables that I did not enter, but that are automatically found (i.e. x, xTIME, etc). Does anyone know what is going on and how to get this to work? Thakn you!
Austin
1 Reply Last Post Mar 22, 2011, 2:27 a.m. EDT
Posted: 1 decade ago Mar 22, 2011, 2:27 a.m. EDT
be sure you have separate variable names for you two models and two physics, then normally it should work. (often it's useful to use latests patch too ;)
Hi be sure you have separate variable names for you two models and two physics, then normally it should work. (often it's useful to use latests patch too ;) -- Good luck Ivar
