Damping in Transient
It seems that in transient solid mechanics the damping is not taken into account. I tried to introduce a structural loss factor but whatever the value i put in the subnode "Damping" i still have the same results.
I also introduced a complex young modulus E*=E(1+i*eta_s) but i got the same results. Did you face this problem?? i'am on Comsol 4.2 and 4.2a
In frequency domaine evrything is ok!
4 Replies Last Post Jun 24, 2012, 5:50 p.m. EDT
Posted: 1 decade ago Mar 1, 2012, 8:56 a.m. EST
For transient models you must either use Rayleigh Damping factors (alpha and beta) or use viscoelastic material and add damping there via relaxation time.
Damping factors only work for frequency domain studies.
Rob
Hi, For transient models you must either use Rayleigh Damping factors (alpha and beta) or use viscoelastic material and add damping there via relaxation time. Damping factors only work for frequency domain studies. Rob
Posted: 1 decade ago Jun 24, 2012, 6:15 a.m. EDT
Thank you dear Robert.
Posted: 1 decade ago Jun 24, 2012, 8:26 a.m. EDT
you find much more in the new 4.3 doc, on structural, and non linear materials, and time domain damping is also possible, in alpha, beta, but not isotropic ,check the equations of your physics when you switch the solver type
And check carefully the doc (PDF files), and v4.3 has been nicely updated
Hi you find much more in the new 4.3 doc, on structural, and non linear materials, and time domain damping is also possible, in alpha, beta, but not isotropic ,check the equations of your physics when you switch the solver type And check carefully the doc (PDF files), and v4.3 has been nicely updated -- Good luck Ivar
Posted: 1 decade ago Jun 24, 2012, 5:50 p.m. EDT
Hello Ivar,
That is very interesting, thank you.
Doudou.
Hello Ivar, That is very interesting, thank you. Doudou.
