Magnetostatics: Convergence criteria of the nonlinear solver are met but not all linear solver conditions are fulfilled
I'm using the "magnetic fields, no currents" module for stationary simulations of nonlinear magnets inside a homogeneous external magnetic field. The simple setup consists only of several blocks of nonlinear magnetic material inside a box/sphere of perfect vacuum. The external field is applied to the boundaries of the system.
Solving this model often results in the above mentioned error: Convergence criteria of the nonlinear solver are met but not all linear solver conditions are fulfilled, when the nonlinear magnet starts to saturate. It most often occurs when using a direct solver for the linear solver. Changing the nonlinear solver between automatic Newton, automatic highly nonlinear Newton and double dogleg, can help or be detrimental.
I don't understand why such a simple setup is so numerically fragile. There are no extreme aspect ratios, no undefined material properties. What could cause such problems for the direct solver? Can it be a mesh problem? I've tried different mesh settings and also adaptive mesh refinement without success. Or the initial value?
0 Replies Last Post Aug 17, 2022, 5:48 a.m. EDT
Hello Severin Selzer
