Simulating Electrocapillary effect
Mobi HM Microfluidic device
I am trying to simulate droplet motion under Electrocapillary Force. I have two electrolytes, one as the droplet and the other as the continuous phase. I tried to couple the TDS and ES physics to form the EDL, but the droplet motion does not occur. Do I need to define surface tension based on the Lippmann equation as well, or is creating the EDL alone sufficient to change the surface tension?I am using a 2D geometry and applying a DC voltage. I have set velocity inlet and pressure outlet as boundary conditions, but at the inlet the velocity is 0​.
I define space charge density in each species as : F_Const( C_cation-C_anion).
0 Replies Last Post Aug 26, 2025, 11:24 a.m. EDT
Hello Mobi HM
