An unexpected error
Hi everybody
I use COMSOL 3.5a to calculate the mode analysis of 2D system . The process is finished successfully, but the calculated results are not restored. and an error report is shown as follows :
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000059a1a685, pid=2212, tid=2856
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b22 mixed mode windows-amd64)
# Problematic frame:
# C [atio6axx.dll+0x3fa685]
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
would you like to tell me what is the reason for the error, any help would be appreciated.
Best regards.
1 Reply Last Post May 28, 2010, 1:06 a.m. EDT
Posted: 2 decades ago May 28, 2010, 1:06 a.m. EDT
check the search on the forum, and the knowledge base, there are a few discussions about similar errors, often its related to graphical libraries not being compliant
Hope this helps
Hi check the search on the forum, and the knowledge base, there are a few discussions about similar errors, often its related to graphical libraries not being compliant Hope this helps Ivar
