Meshing of a thin hemispherical shell
I am trying to find the eigenfrequency of a hemispherical shell. This hemisphere has a diameter of 200 um and height of 140 um, and the shell thickness is 0.5 um.
The hemispherical shell is created by:
1. Using the boolean operation "Difference" to subtract a sphere of radius 99.5 um from a sphere of radius 100 um. This creates a spherical shell.
2. Using the boolean operation "Difference" to subtract the top portion of the sphere using a block drawn at z = 40 um.
I meshed with "Physics-controlled mesh" with element size "Coarser". Because of the relatively thin shell compared to the size of the hemisphere, the number of elements is pretty huge. The file size is too large to be attached here. Is it possible to use the "Swept" function to mesh the hemisphere similar to the way a large, thin rectangular plate is meshed? In meshing the thin rectangular plate, the source and destination faces are defined; the element size can be made large on the face of the plate, but the element size can be made very fine across the thickness of the shell. I would like to mesh the hemispherical shell the same way, with larger-sized elements throughout the face of the sphere, and smaller elements along the shell thickness. Does anyone have any suggestions on how that can be done? Many thanks.
Erwin
5 Replies Last Post Jul 25, 2012, 1:49 p.m. EDT
Posted: 1 decade ago Jun 6, 2012, 12:53 a.m. EDT
often thin shell are better meshed as "shells" i.e. a surface with the thickness attached to the "physics" as you stated you get very many elements. Ideally you should have at least 2-5 elements in the thickness too !!
There are ways to revolve mesh with the sweep function, start from a 2D workplane (you might ness to do it in 2 *180° and not in one sweep. There were a thread or two about this anly a month or so ago, try a search
Hi often thin shell are better meshed as "shells" i.e. a surface with the thickness attached to the "physics" as you stated you get very many elements. Ideally you should have at least 2-5 elements in the thickness too !! There are ways to revolve mesh with the sweep function, start from a 2D workplane (you might ness to do it in 2 *180° and not in one sweep. There were a thread or two about this anly a month or so ago, try a search -- Good luck Ivar
Posted: 1 decade ago Jul 19, 2012, 11:45 a.m. EDT
Hi Ivar,
Thank you for your suggestion. The shell feature does help in reducing the number of elements and speeding up the simulation. It is also more convenient to change the shell thicknesses to experiment with different values.
Apart from the eigenfrequency analysis, I am also performing time-dependent analysis to study how the displacement of the rim of the hemisphere changes with time. I fixed the bottom of the hemisphere, applied a sinusoidal load at one vertex of the hemisphere (not at the rim or bottom), and I plotted 1D graph of displacement vs time at a vertex on the rim. The rim has only 4 vertices for me to choose to study the displacement vs time. If I would like to study the displacement vs time at any point on the rim (not at the vertices), how do I do that? Is there a feature in COMSOL to extract all the data at every mesh point? Thank you once again.
Regards
Erwin
Hi Ivar, Thank you for your suggestion. The shell feature does help in reducing the number of elements and speeding up the simulation. It is also more convenient to change the shell thicknesses to experiment with different values. Apart from the eigenfrequency analysis, I am also performing time-dependent analysis to study how the displacement of the rim of the hemisphere changes with time. I fixed the bottom of the hemisphere, applied a sinusoidal load at one vertex of the hemisphere (not at the rim or bottom), and I plotted 1D graph of displacement vs time at a vertex on the rim. The rim has only 4 vertices for me to choose to study the displacement vs time. If I would like to study the displacement vs time at any point on the rim (not at the vertices), how do I do that? Is there a feature in COMSOL to extract all the data at every mesh point? Thank you once again. Regards Erwin
Posted: 1 decade ago Jul 19, 2012, 2:09 p.m. EDT
you can define a cut line or cut surface by adding a node to your Data Set, and then plot along the line/surface
often I add several lines / surfaces to cut my volumes such to have several entities to pick and plot varables along these internal lines, it's handier than defining cut lines with interpolations (I find it so)
You can set up your own data lists in tables by adding nodes to the Derived Variables node, and then plot he table outputs
Hi you can define a cut line or cut surface by adding a node to your Data Set, and then plot along the line/surface often I add several lines / surfaces to cut my volumes such to have several entities to pick and plot varables along these internal lines, it's handier than defining cut lines with interpolations (I find it so) You can set up your own data lists in tables by adding nodes to the Derived Variables node, and then plot he table outputs -- Good luck Ivar
Posted: 1 decade ago Jul 19, 2012, 2:29 p.m. EDT
Hi Ivar
Thank you. I will definitely give it a try.
Regards
Erwin
Hi Ivar Thank you. I will definitely give it a try. Regards Erwin
Posted: 1 decade ago Jul 25, 2012, 1:49 p.m. EDT
Hi Ivar
I tried to add cut lines by drawing several more spheres and performing the necessary boolean operations and converting them to shells (as I am working on a thin hemispherical shell). However, I cannot "form a union" of my structures, and I cannot mesh.
Is there a way to export all the results to Matlab? I have saved my comsol simulation as .m file, and I opened the .m file in Matlab. However, can I define in Matlab, perhaps using coordinates, any arbitray point on the rim of the hemisphere the displacement-time graph I want to look at? My mesh element is very fine, and there are many mesh nodes along the rim. When I looked at the code, there is a line which looks for the displacement-time results as:
model.result('pg5').feature('ptgr1').selection.set([2]);
This means it is going to give me the displacement-time graph at vertex 2 (because of the [2]). I would like to specify a particular point by using coordinates.
Thanks again.
Regards
Erwin
Hi Ivar I tried to add cut lines by drawing several more spheres and performing the necessary boolean operations and converting them to shells (as I am working on a thin hemispherical shell). However, I cannot "form a union" of my structures, and I cannot mesh. Is there a way to export all the results to Matlab? I have saved my comsol simulation as .m file, and I opened the .m file in Matlab. However, can I define in Matlab, perhaps using coordinates, any arbitray point on the rim of the hemisphere the displacement-time graph I want to look at? My mesh element is very fine, and there are many mesh nodes along the rim. When I looked at the code, there is a line which looks for the displacement-time results as: model.result('pg5').feature('ptgr1').selection.set([2]); This means it is going to give me the displacement-time graph at vertex 2 (because of the [2]). I would like to specify a particular point by using coordinates. Thanks again. Regards Erwin
